Fatigue Testing - Main Tube Gusset Comparision
Sure thing. Correct 1-3/8” tube, 44mm HT.
I can also accommodate small tubes once the new setup is finished. Just have to make the correct size delrin bushings.
What do you have in mind for testing?
I want to send in a TIG welded joint and a TIG welded joint with brazing on top (this is what I do on my frames). TIG is essentially a root pass and the braze makes a larger transition between the tubes.
Is there a specific ht length to use?
Miter angle 90*?
4” HT
90 deg (centered)
24” tube (I can adjust this length though and just scale the load accordingly)
