Bicycle Academy Low Cost Frame Fixture assembly instructions
I currently have an unused LCFF that was purchased before the bicycle academy closed down. You get the calibration instructions inside the box, however the initial assembly instructions were originally online to download. That link is no longer in use and as such I cannot find these vital instructions. Does anyone have them saved? Thanks Clem
Hi Clem, I got a used LCFF too, before the Bicycle Academy closed down. I can send you a pdf of the assembly instructions… Ben
Thanks Ben. That would be most useful.
Hi Clem, I tried to upload it but it would not let me, file too big. I can email it if you provide details…
I’ve sent my address but it’s awaiting approval. Thanking you kindly.
Hi again. clement.jones@aol.com will hopefully let the file through. Really appreciate your time and assistance. Thank you.
Hi Ben, just found your post regarding LCFF assembly instructions, any chance you could send me a copy please… Maurice (mauricehassell@btinternet.com)
If someone gets/has a copy. Maybe they can compress it and upload it here for future reference
I just found a download option for the LCFF assembly instructions:
https://www.manualslib.com/download/1994780/Academy-Lcff-1-2.html
I have a paper copy…
That BB alignment laser is pretty neat tool, too bad theirs doesn’t fit on other jigs… I got a $20 gun sight laser on the internet and welded a little mounting block on a standard BB shell - Blamo! All the jigs can now be checked.
Hi Ben, any chance you could send your PDF of the low cost fixture build instructions to me? It would be much appreciated! chris.tacl@gmail.com
Thanks in advance for your help!
Good solution. :+1:
I have an LCFF with no BB alignment tool (long story) - so made a 3D printable version to work with a laser sight.
I made it available here in case anyone else wants or needs one.
Just sent!
