I’ve got my build log post over here: I'm Building a Wooden Bike!
The way wooden bikes work is that you epoxy in metal (or carbon) inserts for the BB shell, the head tube, and the seat tube. See pic here:
I’m at the stage in design where I want a sanity check on the inserts I intend to put in. I’m a total framebuilding NOOB here so appreciate any advice or warnings that I’m an idiot.
Overall bike will be a gravel bike, going for the ability to put some wide tires on it (50mm). Was going to do a simple 1X group set.
Bottom Bracket
This one is the most confusing. I’ve read the excellent posts by @Daniel_Y : [Standards] Road and Gravel Drivetrains - Cranks and BB's but even then I still feel like an idiot.
My plan was to use a 73mm BSA bottom bracket like this: 73MM X 41MM Ø BOTTOM BRACKET SHELL 7005 THREADED BSA — BICYCLE FABRICATION SUPPLY
I’m leaning BSA as it has the smallest diameter and thus will give me more “meat” around the bb for a wood wrapper. I’m leaning wider given the tire width I want to be able to run, and the clearance issues presented by thicker wood chainstays.
Any objections?
Heat Tube
For simplicity, I was going to go with a non-tapered head tube like this: 50MM Ø X 200MM HEAD TUBE STOCK FOR 44MM HEAD SETS — BICYCLE FABRICATION SUPPLY
I want to put a nice carbon gravel fork on this. Will I be able to find one for non-tapered head tube?
I could make a tapered head tube work, but for V1 it will take more effort. Let me know if my plan is dumb or if I should really make the effort to put a tapered head tube in.
Seat Tube
I was looking at something simple like this: 35MMØ DEDA FIRE SEAT TUBE TUBE 31.6 POST - 35MM X 1.65 X 650MM MTV350E313 — BICYCLE FABRICATION SUPPLY
I would trim it down as I don’t need that much length. I could also actually use carbon, but I don’t know where to find it.
Any recommendations for a carbon seat tube insert? Overall, am I looking at the right diameter?
Thanks in advance guys!!!
