When citing research studies, it’s really important to keep in mind all research has flaws. I think it’s important to read between the lines to get a complete picture.
This is the most referenced crank length study:
Determinants of maximal cycling power: Crank length, pedaling rate and pedal speed
Every research study has its flaws. Just take the first sentence of the experimental method :
Trained male cyclists [n=16, mean (SD) age:29 (7) years, height: 179 (6) cm, mass: 73 (7) kg] volunteered to participate in this investigation.
There is definitely selection bias when people volunteer for studies. Most glaring, a test group of all male cyclists excludes half the population! That was normal for 2001, but would be incomplete in 2023. It also does not mention different body types or ethnicities.
Finally, I think the biggest flaw is not the study, but people’s interpretations of the result. Look at the RPMs that the experiments were conducted:
The optimal efficiency everyone cites is happening above 120RPM. No one is spinning 120RPM on a mountain bike.If you sprint out of corners at that RPM, you are way more likely to smoke a rock, even with your tiny 150mm cranks. If you are spinning a mountain bike at 120 RPM at threshold on the flats… well… you are probably a crazy person.
When you look at this chart, you look at the relationship backwards and still be correct:
- I typically spin at 60-70 RPM on a mountain bike (due to terrain, style, gearing)
- The optimal power of longer cranks happens at lower RPMs
- Therefore longer cranks are more efficient for the RPM’s I spend most of my time at
When I read these crank studies, my interpretation is: AT MOST you gain or lose 5% of your maximum power output in laboratory conditions. To me, that is not enough to make a difference in the real world. So just pick whatever crank length you want.
- If you like to mash go longer
- If you want to run short cranks for ground clearance, go for it
- If you are getting pain, try shorter, longer, wider, narrower cranks.
- If you wanted a more aero fit go shorter
I think the bigger performance gain is easier gearing that allows you to spin more, but that is not as sexy of a topic!
