Frame 4: Succumbing to our new 32" wheel overlords
Frame 4 Fit Notes:
The move towards mainstream of a larger tire standard was an exciting one for me. While not super tall at 6’1~6’2" (~186cm) tall, with a typical saddle height of 800-820mm, I’ve usually ridden 60-62cm and XL frames. For a comfortable fit, Frame 1 had a HT of 222mm, but felt too short, so Frame 2 and Frame 3 are both around 240mm long, all with ~400mm long a-c forks. Drop handlebars are typically an inch or so below saddle level.
Frame 4 Design:
Gravel/All Road/Country Bike, mostly for riding rail trail, etc.:
Rough filing of frame tubes:
Fork
Segmented seamless 1" x 1.2mm with 475mm a-c and 100x15mm thru axle. Straight 1 1/8" steerer.
Reading this thread, the recommended tubing seems to be around 1 1/8" 1.2-0.6-0.8 (Walt sells them here), but the 1" x 1.2mm seems sufficiently robust and I have enough on hand already to make the fork, so no extra cost for my first attempt making one.
Straight 1 1/8" steerer because that’s the tooling I have and I don’t see a real need to upsize to 44mm.
BB Drop
The range for most posted frame designs seems to be around 70-120mm, with most of the gravelesque frames around 90-120mm. I tend to prefer higher bottom brackets, so decided to try 95mm. My Doug Fattic frame jig maxes out at 100mm. This is an experiment.
Tubing
Frame 3 rides very well, but turned out horizontally floppier than I’d like (TT, DT, both 28.6mm 9-6-9, ST 29.8-28.6 1.2-0.6-0.8 external butted), so I upsized the tubing: TT 31.8mm 9-6-9, DT 34.9mm 9-6-9, but kept the ST 29.8-28.6 1.2-0.6-0.8 externally butted seat tube. Bottom bracket is 38mm x 73mm for fixturing and compatibility.
Most frames my size have a top tube length of 600mm or more. I wanted to keep the TT shorter to keep the stem longer for me, but still without pedal overlap. Frames 2 and 3 have TT’s around 575mm. Frame 4’s 590mm seemed a reasonable compromise to help prevent pedal overlap. Also, if friends of different sizes wanted to try riding the bike, having a shorter top tube would mean more sizing possibilities using shorter stems.
Frame Angles
ST angle of 72 degrees is my go-to. It always seems to fit me right. Trying HT angle 69 degrees seems both reasonable and helps prevent pedal overlap.
Chainstay Length and Seat Tube Clearance
The chainstay length range for most posted 32" wheel frame designs seems to be around 470-490mm. I’ve opted for 480mm, but will need to take some room for tire clearance. Building a frame without some clearance modification would require 500mm+ chain stays and that seemed too long. I do not have a means of bending frame tubes to compensate, so I’m playing with some options:
  1. Flat Stock - I’ve always wondered about the viability of using flat stock in place of the seat tube. Rabid Frameworks shared his experience trying this out in this thread. Pics borrowed from his post shared below:
My deviation would be to use a narrower 1.5" wide steel plate and drill larger lightening holes. I’d also leave some seat tube at the bb. To maintain frame structure and work with my fixturing, I’m tempted to braze the plate around the seat tube and then cut the seat tube out. I could cap the tube connections afterward.
  1. Grinding the Seat Tube - Something like Aub3’s work here, but I would need to grind to around half the tube diameter. I have a 12" length of 0.049" 4130 sheet I could use for a smaller section, or else could source a thicker piece of flat stock to add more structure over a longer length. The latter is the route I’m leaning–something like an Option #1 and #2 hybrid.
  2. Double-barreled Shotgun Tube Sandwich - I have hand bent 5/8" tubing ok using a form and might be able to bend 3/4" x 0.035" ok as well, using an old rim as a form. It wouldn’t need much of a curve. Two pieces of 3/4" tubing gives enough material to wrap the 28.6mm seat tube and can be cut with a hole saw. Something like below. Similarly, the double tubes can be brazed in with the seat tube in place and the seat tube section can be removed later.
    Rough concept with an already bent piece of 5/8" tube. (I would use a different radius)
Frame Stays
Shaped chainstays put the bumpout for tire clearance in the wrong spot for the 32" tires, so I plan to use either 3/16 (4.8mm) or 1/4" (6.3mm) plate to make extensions/yoke.
Seat stays will likely need to be custom bent, something like the below. BikeCAD mockup uses GRX 165mm cranks with a max 48t chainring.
I will keep at it and update as progress continues.
Looks great. Take a look at Rob English’s solution for cutting an arc into the back of the seat tube.
Thank you!
https://www.instagram.com/p/DaKWRDcFPj6/
Just saw this post from Sycip Cycles.
I’m really curious about geometry. It was nice and confidence boosting seeing him using the same HT size
Very nice!
I’ve been rather tardy posting updates. Sorry about that. I’ve also not so thoroughly documented my progress. Apologies for that, too.
Most of the work I did in October was on the segmented fork. I largely followed the steps shown here. https://www.facebook.com/share/p/14tmRHQ7Nv4/?mibextid=wwXIfr
It seems to have turned out okay, but I still need to do some finishing, put caps on the tops of the fork legs, and align it. Pictures pending.
I decided I wanted to use GRX drivetrain so opted for a 68mm wide bb instead of the 73mm I had originally planned.
The first attempt at the yoke plates did not go well, but I learned some things. This second attempt went much better. Before drilling the lightening holes and shaping, I brazed the two pieces together so they would be uniform.
You will notice that the first of the lightening holes in the yoke is bigger than the others at 1/2”. This is because my plan is to insert the stay bridge through it. Some filing will be required. The rest of the holes are the same as the internal diameter of the 1/2” bridge tube, so they may look almost the same when viewed from the side. I still remember the first bike I saw pictures of that inserted a tube crossways through a frame tube. It was maybe a Vanilla, Speedvagen, or Johnny Coast. I can’t remember which, but I remember being impressed and thinking it looked slick. This isn’t quite the same thing, but not terribly far off in concept.
Plans for chainstays have fluctuated. I had originally thought about using curved Deda CX stays from Framesetsupply.ca. They aren’t quite long enough for the 480 mm chainstays I’ve planned for this bike, so seemed a bit of a waste to use them with the long yoke plates. Instead, I plan to use 5/8” x 0.035” (16mm x 0.9mm) tubes I have in stock already. They seemed a bit small and light compared to the 3/4” x 0.035” (19mm. 0.9mm) I had been considering using, but comparing the length and thickness of the yoke and the spec on the planned for Deda CX stays I’m replacing, I think they will work similarly.
I also think aesthetically they will be a good match for the segmented fork.
Looking ahead to the seat stays, I have both 1/2” x 0.035” (12.5mm x 0.9mm) and 5/8” x 0.035” (16mm x 0.9mm) tubing in stock, but haven’t decided which I’ll use yet. I had thought about doing a segmented design to match the fork, but haven’t completely decided on that yet either. Most of the length of the stays will be tire, so the may not look proportional.
I’m guessing I have another 30 or 40 hours to go before the frame is complete, so the challenge now is to try to wrap it up before it becomes impractically cold to continue working in the unheated space.
More headway on the chain stays yesterday:
To start, I decided to remove over an inch of the yoke plates. There was enough room for the tube section of the stays without conflicting with the crankset. I think it looks better, reduces weight, and I don’t believe it will negatively affect the durability or ride quality of the frame. This sketch shows the 68mm BSA bb, 151mm Q-factor and ~48mm chain line (47mm for a double, 50mm for a 1x) of GRX crankset. Max chainring size should be around 48t. I like short cranks, but this frame should have clearance for 175mm cranks ok.
The technique of attaching thin tube to thick plate was a new one for me. I am grateful to have found example videos by those more skilled and practiced than me. This one from Chapman Cycles was a big help. Em @WZRD’s video changing out chain stays here (start at about 8:40) was also super helpful. A screenshot from the video is below.
My first couple of attempts to braze the two pieces together didn’t go well. I tried tacking the plate and tube on the inside edge using a 0 tip on my torch so I could remove the clamp before continuing. See where the metal meter stick in the background crosses the work. I did this, but the tack didn’t hold and I had to clean everything off and repeat the process again.
I was also worried about overheating the tube and wanted more practice, so I used some scrap material. Brian Chapman’s heat control is impressive. The few times I have tried to use the techniques I see in his videos, I’ve found I do much better with a rosebud attachment on my torch. This was no different. It worked a lot better for me than the 0 tip.
I did overheat the piece to red, particularly at the tip of the tube. The burn flux there is obvious. To cap the tube, I went back to the 0 tip, thinking it would be more precise. Adding bronze from the outside was a mistake. Adding it inside the tube is key to ensuring a good fillet and easier cleanup. After the practice piece was completed, I cut it in half to inspect the internal fillets. They looked good, so I felt ready to try again on the stay material. I rethought my approach and decided to more or less only apply heat to the thick plate from the bottom, away from the tube side of the assembly. I was pleased with how consistent the plate showed its heat through colour with the use of the rosebud. The plate got just nicely to orange, never red. Instead of the Amazon clamp (with plastic parts removed) I tried the first time, I used a proper spring clamp to hold the parts together. It worked much better. I bought the Amazon clamps with the hope they would be a budget- and tariff-friendly stand-in for Cobra’s Braze-on Clamps. With replacement screws, I think they could work ok, but I do look forward to owning an using a set of Cobra’s clamps in the future.
Like many things, the first stay assembly took about 10x the amount of time and energy to put together than the second. In the end, I like how they came out.
Sequencing for the next steps will take some planning:
Where the yoke touches the bottom bracket is filed to fit as if the plates meet the bb square on, not on an angle. So next, I will drill out the 1/2" holes in the yoke pieces for the chain stay bridge to sit straight and then silver in a piece of 1/2" tubing to set the chain stay assembly in place. My chain stay jig should work ok for this. While I don’t have fittings to hold the plates securely in place for mitering (for example), what I do have should work well enough, perhaps with some braces, to hold them for silver soldering the bridge okay.
With the bridge set, the chain stay assembly should now sit securely in the vise and I can file the yoke to fit the bottom bracket.
After that, its adding dropouts and then, following @guy153’s recommendation, attaching the chain stay assembly to the bottom bracket with the seat tube attached. BikeCAD will give me the correct angle.This will take place in my chain stay jig, which sits everything vertically.
Once that is complete, the ST/BB/CS assembly can go into my front triangle jig (which lays flat on a table) and I can finish brazing the frame together.
Once that is complete, its alignment time, followed by the shaving and reinforcing of the seat tube. I have started gathering parts to make my own version of English Cycle’s tool.
After that, seat stays, bridge, and braze-ons, chase and face, etc.
