Idk if this is correct usage of this forum, its my first psot . Anyways, I i’ve been building up and painting bikes for a few years now but finally started getting into the actual fabrication and brazing side of it. After cutting my disc tabs from 3/8th inch mild steel and fitting them to fit with my jury rigged jig I fell in love with brazing. I know my joints arnt perfect and maybe my bike isnt even safe, but I just wanna get better and better making frames and brazing in general. The problem is I dont really have a space to use, or thr funds to afford any kind of premade jig (i was thinking about making one out of wood? (Non adjustable for a single frame use)). That being said, if there are any people in Portland who would be interested in showing a young person around frame construction and fixturing etc, lets get in contact! I have been learning bikeCAD and about geometry, and would love to help out maybe do some prep work, and learn more about building frames!
From what I can tell, you can’t swing a cat by the tail without hitting a framebuilder in Portland.
Go knock on doors, show them what you’ve done and ask for feedback. Then go home, practice with the advice they gave you. After you’ve made progress (2 weeks max), go back for more feedback/advice. See it done, don’t ask.
Work on your TIG and your brazing. Look for openings at Breadwinner or Firsthand or start pestering any frame builder who will give you the time of day. Look for union apprenticeships in a trade that will get you some time under the hood or behind the torch. There’s a wide variety of fabrication skills required for frame building and those skills can be developed in a range of industries that are completely unrelated. Plus you’ll make some decent coin in the meantime. If you’ve developed some serious chops in the paint booth and you’ve got the tools and the space, see if you can get a skills trade going with a builder who needs a painter. Good luck.
You can certainly make your own jig. Pithy Bikes documented making a wooden one below. I made mine out of metal. I actually think metal is easier to work with than wood, and it’s all good welding practice!
