Hi everyone,
I’m a small-scale frame builder from Wuppertal, Germany. I run a bike shop and build a few frames on the side. Right now, I’m cutting all my tubes by hand and filing each one individually. To be honest, it’s quite a lot of work and not very precise.
I’m thinking about getting a machine or something else to help me with this process. I use BikeCAD for my drawings, so I have access to miter templates.
Does anyone have a recommendation for me? Should I save up for a milling machine or a belt sander? I’d appreciate it if I didn’t have to go through the trouble of modifying and adjusting the new machine first.
Thanks a lot, and happy frame building!
If you’re short on space buy the tool that will solve the most problems. For me, that was a mill.
I’ll add that buying something to miter tubes isn’t exactly a shortcut. Early on a builder told me “Build 25 frames before you invest in tooling.” He was right. If you’re early in your career it’s worth it to really figure out where you’re going wrong so that you can apply what you learned down the line.
In terms of buying a machine, you’re going to have to set-up and adjust it. There’s a youtube channel called BlondieHacks that covers buying and setting up a benchtop mill. It’s worth checking out that channel.
Don’t think that a machine cut miter doesn’t need any filing to fit best. I do agree with using a mill for mitering. I’ve made a bunch of little fixtures and jigs on it too. Andy.
A proper mill is an incredibly useful tool, but small mills can also do this job. I have an Emco FB-2 (which may be easier to find in Europe) that fits on my workbench and does a fine job of mitering tubes using standard hole saws. I used to have a much larger mill and I’d be hard pressed to say that the bigger mill was better at mitering.
There is a limit, my first mill was the tiny Seig X2 and that mill didn’t have the rigidity for the job.
I had the exact same question a few years ago. I ended up buying the tube notcher I linked. It was a good in between but still needed a bit of clean up. I have since bought a full sized mill and it is way better, but, even a 3000 lb mill doesn’t make a perfect miter.
These help a lot! Cuts so easily, and makes the miter much more centered and correct sized.
These do need straightening before use, however…
Notchmaster. Still the best tool purchase I ever made and still the thing I cut most of my tubing with. Requires a tiny space and I really like handling speeds and feeds by hand with thin tubing.
I bought a few of these to test and was surprised how much wobble/runout they had. Do you just knock them into running more true or whats the procedure?
Yes, tap it until better… But first you can take a light pass from the mounting face on lathe, to remove the thick paint, and luckily the runout gets better too.
Exactly, I grind off the protruding teeth of a new saw with a belt sander, then chuck it up in the lathe and face off the mounting face. Generally this is enough to get very good miters.
May I respond in German, since we are both from (t)here?
Ich mache einen Teil der Gehrungen mit einer alten Fräsmaschine, einen Teil mit der Feile. Die Maschine ist eigentlich überqualifiziert, ein paar gute Feilen sparen Dir viel Geld. Und länger dauert es auch nicht, weil das Einrichten der Maschine auch seine Zeit benötigt — außer Du hast entsprechende Vorrichtungen, also weitere Investitionen.
Wer macht gute Feilen, die Du in Deutschland kaufen kannst? Wenn ich die von Dick bei meiner Werkstatt-Kollegin anfasse, bin ich als Pferd-Feilen-Nutzer richtig neidisch. Baumarkt ist eh Murks.
In Sachen Fräsmaschine noch ein Tipp: Achte unbedingt auf den Z-Weg! Meine Steinel SH4 mit Vertkal-Fräskopf hat da oft zu wenig.
If you use tin snips (aviation snips) to rough the end of a tube first you will have a lot less filing to do afterward.
I don’t think Wiss is German but it might be Swiss…
You are in Deckel land. Pickup a Deckel FP2 mill and don’t look back. You can mitre tubes using a horizontal or vertical quill and make all the tooling and fixtures your heart desires.
