Long shen oversized lugged BB shell width
Long Shen Bottom Bracket Shell, OS, 24OV CS – Metal-Guru.com
Hi. I’m interested in knowing how wide this BB shell is. And if the dimension is known, what angle and distance apart the CS sockets are.
The width will be 69mm with the intention of facing to 68 when finished. CS sockets are at 7.5 deg and will be around 42mm apart at the centerline (from memory)
