Any wisdom with regards to how close a butt can be to a weld/braze joint?
25mm is always what I used as a bare minimum. But I like to have quite a bit more where the action (ie head tube) is.
Is the 30mm valid for lugs as well? How long should the butt section go beyond the tip/point of a lug?
Others may have more experience based feedback but I always make sure the lugs tips are within the butted area. I’ll shorten the tips up a little if I need to.
Thank you!
I guess that if it comes down to filing the lug, only a few mm within the butt section will do the trick? I currently have about about 3-4mm.
You also have probably 40mm of transition so a mm or two should be fine. Also, if you’re tubes are so short that you’re running out of butted material, the frame may be for a light rider which will also be in your favor. The bottom lug extensions should also be broadly rounded, not pointy.
Might be slightly off topic, but why do you want the bottom extension of the lug to be rounded off? I guess it’s to distribute stress over a larger surface?
I’m currently bulding a frame wiith a Long Shen 102R seat lug and the bottom is quite pointy.
Yes, I round those off. If you thin them, it seems the risk of them acting like a can opener is decreased.
To be clear, I don’t have any scientific data, but that point can’t be good for the tube (especially on the thin walled section!) and a rounded off lug just makes more sense to me. I have heard other builders say the same so, I’m going with Lore & Magic vs Engineering & Science. ![]()
That is the general understanding and I do that as well. Round and thin a little. Stress is always better handled with gradual changes. Avoiding steps in material and points/corners is always better. When you join a tube and lug they effectively become one. that said we have millions upon millions of lugged frames made over decades that are fine with pointed lugs.
