Product Details
Material: 1018 steel, includes right and left frame components
CUSTOM ENGRAVE (see photo) your company name or logo on the left side frame component:
- One time $65 programming and set up fee
- $5/pair engraving charge
- BUY 10+ PAIR AND SET UP/ENGRAVING ARE FREE!
- Engraving must be done during the manufacturing process, order in advance
- Email orders(at)paragonmachineworks.com for more information
Application:
OD: 1-3/4"
Flanges:
- Width: 1.180"
- Symmetric: Side-to-side chainstay and seatstay
- There is approximately 3 mm per side to make the weld with 7/8" chainstays
- There is approximately 5.5 mm per side to make the weld with 3/4" seatstays
- Push the seatstay outboard as far as possible to avoid SRAM’s clearance mask
Caliper Mount: Flat Mount Integrated for 160 mm rotor (direct) or 180 mm (with adapter, adapter not included)
Wheel Alignment:
Concentric: use a 0 mm offset bushing
Eccentric:
- Select a 0.5 or 1.0 mm offset bushing
- For 0.5 or 1.0 mm bushings use a 2 mm hex key to rotate the insert using the radial holes on the flange
The bushing is a structural part of the assembly and must be welded in
- Once installed it is not meant to be consumer serviced
The chainstay center MUST be 3.5 mm above axle center to meet SRAM’s specs
Use the flats on the bottom of the dropout to index:
- Put a straight edge on the flat and position it 13 mm +/- 3 mm below bottom bracket center
SOLD SEPARATELY: The bushing, skewer, and SRAM UDH/Transmission
PART NUMBER DR2075
