Hi gang,
I figured this would be a good place to document my progress on a new undertaking. I paint all my own bikes with 2K automotive spray system using an improvised setup at my house/in my backyard. I’m pretty happy with the results, but I’m often fighting two major issues:
The time to let things air cure can quickly get away from you, especially when you’re masking between colors, and the short windows for chemical adhesion from starting basecoat to getting clearcoat means I’ve often still been painting at 2am (since I do framebuilding off-hours from a normal day job) to get it all done
Once clearcoat is on, I’m waiting days to get enough strength to feel comfortable building up the bike, and even then scratches are inevitable for the first few weeks.
In addition to these paint factors, I currently dabble with making my own carbon fiber parts- right now just a custom profile seattube but I’d love to do more. To do this with prepreg requires the ability to get your parts up to 120C, which is doable using direct heating methods on a single tube mandrel like i’m doing now, but is impractical for anything requiring a traditional mold.
Finally, not everyone needs or wants a urethane paint job. For bikepacking, mountain bikes etc, it’s more practical to look at powdercoat or cerakote options, but these also require high temperatures and the ability to bake an entire frame.
Thus started my interest in figuring out an oven setup. Requirements:
- Be able to reach 120C setpoints and hit the temperature ramp targets set by the prepreg manufacturer (1C/min or so).
- Be able to fit an entire bike frame, with fork, with stem/handlebars/accessories in one go
- Be able to fit a ~1m tube mold for custom carbon parts
- Fit in my basement and be compatible with standard US power (240V single phase)
- Not cost an arm and a leg
This has been a lingering idea for most of this year, but just this week, the perfect opportunity arose!
Lo and behold on my local FB Marketplace, the perfect starting point. An industrial cabinet designed around fully insulated chamber walls and an industrial control panel up top, fully modular for my use case, and in a size literally perfect for bike frames! I jumped at the opportunity and came down to look at it- the guy didn’t really know or care what it was used for before and was going to junk all the electronics to build a powdercoat oven- his loss.
After salivating over this guy’s home shop (complete with a home FORKLIFT), we shoved this thing in my truck (and squatted the hell out of it) and I brought it home. A six pack of beer and some pleading later, I had a brute squad out front of my house to help haul this thing into the basement. I have a walk-out setup, so everything in the shop has to come down a grassy hill until we can shove it through a standard door frame- if and when I ever move is gonna be a bad day, but doing this one at a time over the years hasn’t been the worst. I took the doors off to make it more managable- they must weigh about 80lbs a piece. The cabinet all together must be about 500lbs. Lots of fun, but we muscled it in!
The controls are literally bespoke to my use case and insanely tidy:
It was clearly built and intended for japan, then shipped over here and run on US 3-phase power. It has a PID controller, separate timer, relay bank for 3 independent heating coils, and 3 separate thermocouples mounted in the case for monitoring. There’s a plenum at the top with 3 coils and a fan bank blowing down.
At first I couldn’t believe my luck as this is already 90% of the way there. However, digging in more, things started to pop up, the most obvious being that the current heater/fan setup is designed to work at around 60C- great for paint curing, but not gonna cut it for my full needs. To get up to 120C, I’m gonna need higher capacity heating elements and an externally mounted fan setup.
Going to methodically pin out the control box this weekend so I have a full lay of the land, then plan out my ducting/heating strategy to upfit this cabinet next.
