I had one of this fork crowns and all the other parts, so I built a new one. In my head always the question, why did it crack? Just before sending the new one to the painter I realised, I cut the legs square, so they don’t go all around to the top. Maybe the colleague did it the same way?
I decided to build another one, the legs cut to the inner shape. When starting, I noticed some small lips in the fork crown, all at the same height. Obviously to hold the legs.
Here’s my anecdote: I have but 4 lugged forks for myself and cut the legs square to the inner shelf every time. I am 205cm and was like 120kg at the time and never had a problem. I once went otb and the fork cantilevered my toptube and broke it. The fork was fine.
Each crown type is different. The one you have here as a replacement with the little shelf inside there is designed to have a square cut tube. Some don’t have the shelf but generally, cutting square is the right solution.
That crack looks like a bad casting to me from the pictures.
Back when I worked on gas turbines, we had regular meetings about bad castings because they make the engines fly into pieces. Parts were liberated! It looks like it might be a bad casing with cracks coming out of it. I wouldn’t ride it.
I don’t know why they would drill a hole on the back of that crown. I drill into the steer tube. That way I can look inside and admire my brazing.
If a crown is made to have flat fork blade ends, I have always done that without really thinking about it. Those crowns are plenty strong, and I’m not sure making the blade fit better at the top would really do anything.
