I stopped building frames almost 15 years ago. Recently I found some boxes with parts and tools I will sell here. PICTURES BELOW
- NEW Silva Bottom bracket treading and facing tool. ITA tread. This is a beast of a tool. Never used. Original packaging this there. Some of the rubber/latexy protection covering is stil on the cutters. Still manufactured so other cutters are still available. But I do expect other EU brand cutter might fit directly or with small modification. I am asking 750 Euro.
- used twice Silva brake bridge miter attachment for press drill or milling machine. Comes with 6 (is that the full set?) of bridge adapters. 1 is still in original sealed packing. Really nice tool if you do a lot of brake bridges. I planned to modify one of the adapter to be able to quickly miter non-brake seatstay and chainstay bridges. Make quick work of this job. Does make the most annoying small metal splinters in your shop. I used the vacuum cleaner after every use. I am asking 650 Euro
- Silva front derailleur hanger brazing fixture. Now is setup for 28.6 seat tube and BSA-ITA BB, but easily modified. I am asking 350 Euro.
All these tools are still available. Please check them out to get an idea of the quality if you are not familiar with Silva.
Can be shipped anywhere at buyers cost.
Picking up from my location in the Netherlands (Koudekerke, Zeeland) does have my preference.
I will consider an offer on all of these together of individual.
I also have other items I will try to post asap. Including a Bringhelli frame that was upgraded by me and I used to build my first 15 frames. And a nice set op Ghloor Acet/Oxy pressure regulators. And a hardly used Lorch DC Tig welder.
Cheers.
https://www.instagram.com/p/DXrxeRFiNNY/?utm_source=ig_web_button_share_sheet&igsh=MzRlODBiNWFlZA==
