Tig welding super light tubing (0.7mm)
Hey everyone, lining up to build a super light cx bike. The main tubes are 0.7-0.4-0.7 wall thickness. I’ve tig welded an equally thin 4130 tube before, and while very annoying, didn’t have issues once built.
However, ive been seeing some things said here and there about how tubing that thin should only be brazed due to lower temp etc. Does anyone have experience and opinions building super light tig bikes? Anyone have scientific research on this?
You can perfectly well TIG weld it. I’ve used 0.7 wall tubes and even 0.6mm seat-stays.
Make sure you get an externally butted seat-tube. Note that almost all the joints on the frame are thick-to-thin (the only exception is the small region where the seat-tube intersects the down-tube, and bridge-tubes). So always start the arc on the thicker tube and never forget which is which. Then dip the rod, and pulse the pedal up a bit as you wash the puddle onto the thinner one. This works for me anyway. Any small error and things will go south very quickly so be careful and if in doubt lift off the pedal at once.
I like to TIG braze bridge tubes as they are non-structural anyway and there is much less risk of weakening the tube you care about-- the stay-- but you can also weld those. Just be extra careful because in these cases both tubes are thin.
If you use Reynolds 853 the heat of welding should actually make it a bit stronger! But it’s fine to TIG any of these tubes (and the stays I use are 525 which is just regular 4130 cromoly).
I have a document from Reynolds which discusses welding. It certainly doesn’t say that you shouldn’t use it on the thinner tubes. They suggest using ER-70S-2 , ER70S-6 or ER80S-2, which are all very normal mild-steel rods, on everything except the stainless tubes. I use one of the ER70 ones. Some people like to TIG all frames with a stainless filler. They don’t mention this in that document.
I only made a small number of TIG frames with .7 — Col. EL or Prestige mostly but also some tandem keel tubes in .028" 4130. None of them broke, that I know of, but some people don’t tell you when their frame cracks if it was years later. I am not a great TIG welder, so there’s a good chance you can weld 'em as well as I did and likely better!
I would maybe consider back purging the frame while welding to give a bit more “safety factor” to both the process and the result. I feel that things don’t go south as quickly when there’s less oxygen present around the work area…
Interesting. I’ve never set up back-purging as I don’t do stainless or Ti. It’s quite a bit more hassle. However there are a few places where I use a bit of aluminium foil to keep the gas where I need it.
Thanks great info. I used a mix of er70s-2 and er312 on the thin tubes I’ve welded. Stainless seems to flow better at lower temp which makes it easier to do a pretty weld, but should probably be backpurged.
Been thinking about this too. Just did some stainless vessels at work and having a purge really makes the whole process better.
Yes the thin steel frames I welded (a few dozen tops) had an internal purge, because we were set up to make Ti frames (and Metax stainless, and Aermet 100 alloy), so all the stuff to purge was right there. Why not? I wasn’t the guy paying the argon bill, and on the rare occasion where I blew a hole through the tube, it made fixing that a lot easier than if the hole was made of oxidized steel. Yes I know, “just don’t make holes in the tube while welding”, great advice, not easy to live by 100%.
All great responses above.
This is a case where you would definitely want to use a .040 electrode and some .035 filler wire, A lot of heavier tubes I’ll probably use a 1/16 electrode and .045 filler but in this case you want to be careful about not sending any extra heat into the thin main tubes so the finer electrode will help you control that. And the thinner filler wire will melt quicker and easier and cool the weld before the thin tube gets too hot.
The extra "wetting” action of a stainless filler (weldmold) is nice too in helping create a more consistent-looking weld bead which is hard to control on very thin tubing which doesn’t have a lot of heat-sinking action.
Agree about a thin wire (I use 1mm, which is about .040) but I actually use 3/32” electrodes just because those are what fit into a Furick Jazzy 10 cup which I find gives me the best gas coverage of those I’ve tried. I don’t find them much different to 1/16” electrodes to use. Haven’t tried even thinner ones! In theory if you grind an electrode to a sharp point (i.e. steep sides going up to the tip of it) you should get an arc that wants to penetrate a bit less, which is what you want on such thin material.
Have never tried a stainless filler, I should probably get some to see what it’s like.
Another great point about the finely ground (acute) electrode.
Fay Butler (car guy not bike guy) has a very different electrode grinding idea which has to do with current density and uses a much more obtuse electrode tip - the idea is to put as little heat as possible into a body panel. But this is for welds that get ground flat and is only applied of relative flat surfaces, it wouldn’t work well on tight inside corners.
I bring this up as an example of how welding theory (current density) and welding practice (limiting where the heat goes) can be two very different things.
Le nickel argent ou l’ argent se fait a très basse température argent sans cadmium 50%
Oui cest ben vrai big mais là on parle juste de la soudure pas brazage
Thanks everyone for your tips and info, all appreciated.
In the end I was way too apprehensive, it was no trouble at all haha. The biggest problem was gappy miters but even then it went ok. :+1:
