Tubing Diameters
Hi All,
I was wondering if anyone had input on common diameters for tubing on steel frames. I was thinking of breaking down answers by tube and bike type. The format I had in mind is as follows.
Top Tube
Road Bike - Diameter/Thickness
Gravel Bike - Diameter/Thickness
Mountain Bike - Diameter/Thickness
Down Tube
Seat Tube
Chainstays
Seatstays
This was the format idea I came up with, feel free to copy and paste or answer the ones you feel pertain to you the most.
If there are a good amount of responses, I can create a PDF/Master Post for people to reference in the future.
I think there’s too many variables you’ve left out for anyone to provide a complete list. For instance, if I were making a road bike for a 5’2" rider weighing 110lbs, I’d use different tubes compared to someone 6’0" and 200lbs.
Still, it’s an interesting topic that doesn’t get talked about much. Maybe if you provide an example rider and draw up a frame in BikeCAD for each bike type, some people will respond.
Here’s a good article that talks about how frame tubes influence the ride.
I love this idea! This is my current understanding of contemporary steel bikes (thru-axle, stiff wheels, 31.8 bars, carbon fork, etc…)
  • I won’t call out butt wall thicknesses unless I think it’s important. Diameters contribute the most to tube properties.
  • These are for an average male, 5’10 180lbs. I would step down the diameter for people 5’7 and below.
Top Tube
Road Bike - 28.6
Gravel Bike - 28.6
Mountain Bike - 31.8
Down Tube
Road Bike - 34.9
Gravel Bike - 34.9
Mountain Bike - 38.1 with extra thick HT butt (1mm or more)
Seat Tube
Road Bike - 28.6 bulge butted (1.2mm butt)
Gravel Bike - 28.6 bulge butted (1.2mm butt)
Mountain Bike - 34.9 (1.65mm butt)
Chainstays
Road Bike - 19.1
Gravel Bike - 19.1
Mountain Bike - 19.1 + yoke
Seatstays
Road Bike - 16x.9 (you can probably get away with 12.7)
Gravel Bike - 16x.9 (you can probably get away with 12.7)
Mountain Bike - 16x.9
Thank you for this link! I had this article bookmarked ages ago and would reference it often until the link died. The Wayback Machine for the win!
An early side project of mine has been measuring real-world torsional stiffness of the frames in my shop and correlating that to “ride feel.”
While not the most scientific metric, I think there would be some merit to a relative benchmark test to help inform some tubing profile decisions.
Arbitrary example: for the same load, a frame that deflected 6mm rode smoother than a frame that deflected 4mm. A frame deflected 8mm felt noodle-y, etc
Reminded me of this
https://www.sheldonbrown.com/rinard/rinard_frametest.html
Exactly this! Thank you! I’ve not seen the article before. Maybe the work is already done for me :sweat_smile:
Thank you so much for sharing this! Definitely helping to point me in the right direction.
Copy that. Thank you!
Useful information Daniel. Because you mentioned contemporary steel bikes, how do you see things like stiff wheels and carbon forks influencing tubing selection? Sounds like there’s a concern that they might not play well with flexy frames. The thing that stands out to me is the DT size, which is one size larger than what you’d call “traditional” OS tubing.
Obviously disc brakes → stiffer forks, etc etc
It’s true that diameters matter the most, but when I’ve done the beam deflection math it does look like thickness matters. My rule of thumb is that a 7/4/7 tube rides like a 9/6/9 tube one size smaller (so a 7/4/7 28.6mm top tube has similar ride characteristics to a 9/6/9 25.4 (or standard) top tube). The larger diameter but thinner tube is lighter, but more expensive and probably easier to dent.
Personally I like the ride of classic “standard diameter” tube sets for road and gravel bikes and only go up in diameter if I’m also reducing wall thickness.
I can only see using 34.9mm downtubes on bikes with a really long front center (like a progressive MTB). I have a mountain bike made by someone else with a 38mm downtube and like most aspects of the bike but look forward to making its replacement with skinnier tubing.
