Im building up another bike. The usually supplies have no yokes.
Anyone have one that they can sell?
Mtb with T47 bb. 19mm CS. I will be building in steel.
Bump. I still can’t find any.
Have you thought about making your own design out of flat stock and having it cut and bent? I made a batch of them for Elephant Cycles using Send Cut Send and the per unit piece was really great. It was a fun side project too, and now we can get more whenever we need them.
What about Cobra?
I have no cad skills and not much time to learn. I may try eventually
Let me know what you need.
I’ll draw it up for you in CAD.
It’s fun to interpret napkin drawings. ![]()
This is a 3D printed model of the one that I designed for the Elephant NFZ. That’s a projection of an XT M8100 crank with 36t ring and a 68mm BB shell offset to match the 73 that we use. I have a few design tweaks to make for the next batch, but it overall worked nicely.
I found Ben Land’s video in this thread useful along with other nuggets in there. Kona uses similar yokes on a lot of their steel bikes like my 2019 Honzo ST.
SCS is awesome to work with and produced these in about a week. Per-unit pricing drops significantly at only 2-3 yokes worth, so it is affordable to experiment a little bit.
Thanks for the info. I will check it out again.
Do you need both sides or just drive side? Mitering a 3/4"x1/4" plate and bending a s shape isnt too hard, you could even make both sides like that and put a regular tube bridge. We have a batch of laser cut& bent ones for profiled chainstays (1" wide but you can taper the other end) i could probably send some if you cant find anything else
Bicycle Fabrication Supply just announced a 10 day pre order for plate and printed metal yokes.
I already ordered some printed yokes from a member on here but will order a few plate yokes.
