Introduction Thread
Paul,
In a shameless promotion of our business, I’d like to point out our Snap Ring Dropout:
They are not traditional, but if you have a rider that prefers 12 mm skewers, this is a good option. It is the lightest commercially available 12 mm dropout. With tapered stays, it makes a sharp looking rear triangle. There are multiple hanger options to accommodate most drive trains, and are easily replaceable. Also available in stainless steel for a shiny accent.
Thanks, Mark.
Hey I’m Jon, I weld titanium frames in Seattle for Davidson and a new bike brand called Mischief. Always been into frame building. Worked at S&M in CA for a few years.
I have built a few BMX frames for myself and friends. I’m here looking to glean as much as I can from you experts and also contribute what I’m able to.
Welcome Jon!
I also used to weld Ti frames for Davidson — 30 years ago! I’m the one that dragged him kicking and screaming into Ti, he was very reluctant at first.
Does Bill still come in to work or has he fully retired?
Are you full-time at Big D, or do you have a “day job”?
I’m in the neighborhood, maybe I’ll stop in for a visit some time if that’s allowed.
Cheers
Mark
Oh ya Mark, Bill is in the shop 6 days a week! I’m sure he would love a visit. I do have a day job, I do the bike stuff before/after work or on weekends usually. I would be interested to meet you and hear more of the history of that brand.
Hey Guys!
Im Max, 25 Years old and a beginner in Frambuilding from Germany. I started building Steel Track Frames but i really want to build some Aluminium Frames next year.
I mainly ride Fixedgear or Singlespeed Vintage Track Bikes but also a Carbonfiber TT Bike with a Disc for long distances.
Im really happy that i stumbled about this forum since theres little information about bike framebuilding in german
Mark is an amazing resource for the history of Seattle framebuilding
Hi Max,
There are several aluminium welders here (including myself).
There is a thread in the Education section which might be a good introduction, and a place to place aluminium-specific questions.
Always happy to help.
Dan Chambers
Hello everyone. My name is David Werner, and I have a lifelong passion for cycling and all things metal. I am happy to be on just about anything with wheels and pedals, but am most attracted to mountain biking.
I have been blacksmithing for 26 years and have worked in and out of metal fabrication, custom bladesmithing, historical armor reproductions, casting, jewelry, and manual machining shops all around the St.Louis and county area.
I have wanted to make a bicycle for the longest time, but only just recently started putting together a real effort to create a plan and learn how to go about building more than just a “Frankenbike” from spare parts and tube.
That’s my story! Thanks for having me and for being generous with the knowledge you have posted here.
Welcome David! Your blacksmithing experience will serve you well, and your bike will turn out awesome. Keep us posted.
Hi all, I’m Marc. San Francisco-based. Lifelong cyclist - more mountain than road. Was a very active member of MTBR starting in the late '90s and then Ridemonkey thru the '00s, so if you recognize the handle… its the same “ohio.”
Decided to take Danielle Schön’s framebuilding foundations course back in the Fall of '22, while in the midst of what ended up being 2 years of wrist surgeries and going on 3 years of being off of bikes. I’d had an IF Crown Jewel ('01 with a 1" steerer) and still have a DiSalvo 10th Anniversary frame, both of which I loved, but neither had precisely the fit, aesthetic and details a really REALLY wanted. So I built this guy as a classic-ish frame, but with
-slightly slack, low, forward and long geometry (71.5HA, 74SA, 75mm BB drop, 415mm CS
  • a mildly sloping (7deg) TT to help me get a taller stack height than a classic race bike, but keep an aesthetic close to a level TT and alignment with the stem
  • internal cable routing and full length housing
  • Columbus Life tubeset with the smallest dia factory s-bend seatstays I could find to smooth things out a touch
  • OS downtube to have more torsional stiffness than my previous frames
    Here’s the result… although in the process I learned that painting is even harder than brazing, so that will need to be redone at some point.
    I FINALLY was able to take it out for a maiden voyage today, nearly two years later. Quick notes are:
  • I love the geometry, and the choices made on tubing shape and size. Bike feels like a part of me.
  • Holy shit, the Campy brakes, Campy red pads and EIE graphene rims are really impressive. I love really powerful brakes (run 200mm Dominion A4s on my MTB), so had low expectations. But these were really impressive, even from the hoods. Definitely have more brake than tire even on dry pavement.
    Quick BUILD notes are:
  • my internal routing kinda sucks. I used an internal housing cover, and the opening diameter is designed for tube-within-a-tube, not standalone. Still hunting for rubber grommets (approx 4mmID/7mmOD) that can seal the gap and hold my housing securely in place.
  • I snapped the head off of the diving bell housing stop for the front der, trying to drill it for a 4mm housing end (they seem sized for bare 4mm housing), so am currently running a clamp-on stop, and will fix that when I’m also ready to redo the paint.
  • I still need to finish the head badge. My sister in-law does gorgeous, playful brass and enamel craft jewelry so I was going to have her make something for me… until then I just have two tiny M2 threaded holes in the headtube.
  • I’m glad I went with an aliexpress seatpost and UNO stem while I was still figuring out how to paint, as my paintwork was shit and I would have hated to ruin something nicer. Also, both seem very functional and well finished. Ask me down the road when one or both snap over a pothole on a descent…
Edit: weight as shown with cage and pedals is 16.8lbs.
Nice one @ohio
Any plans for an MTB?
Bike looks great! Fancy paint is for the bike shows. As long as you got good coverage and adherence then I say run it as long as it lasts.
Beautiful build! Ill keep an eye out for it in SF!
Probably not anytime soon, unless I take another class like Danielle’s… I have a hardtail sketched out in BikeCAD with some geometry tweaks I’d like to try, but I don’t have the shop to build it.
Plus with my neck and wrist still recovering, a hard tail might be the worst idea… :rofl:
I got a notification that I’ve been a member of this forum for a year but I’ve never properly introduced myself.
My name is Johnmark. I’m a mechanical engineer currently living in Cleveland Ohio. I started mountain biking but eventually branched out into road biking and touring. The idea of building a frame was bouncing around in my head for a long time. A year ago decided to take the plunge. I bought a book about lugged frame building and started absorbing all the info I could online. My first post here was asking for advice on silver brazing. This forum is the most active and informative frame building community I’ve found and it’s been an invaluable resource for me as a ‘self taught’ (nobody is really self taught…) hobby frame builder. On a side note, frame building is a very niche activity both as a profession and hobby, which fosters a community where pros and hobbyists intermingle. I think that’s really cool and is something I’ve never experienced, or even heard of in a community before. It’s like Micheal phelps giving me advice on how to tread water.
Anyway, here are some photos of my journey as a ‘maker’ and a cyclist.
My first real bike as an adult. Sold to me by a coworker for very cheap. The second pic was it’s final form before I retired it.
The bike I toured across the US on. I learned a lot about bike geo and fitment with this one. It was originally a cheap schwinn hybrid. This bike also had my first “custom” part made using a kind stranger’s drill press mid tour after my hose clamp rack mount’s started getting loose.
Some more early custom bike parts.
I sewed these bags myself. The frame bag wasn’t turgid enough, hence the duct tape in the second pic to stop it from bulging out against my legs. I haven’t sewn in a long time. Maybe someday I will re-visit that.
My first frame build. Built about a year ago. It’s far from perfect. There’s things I would change, but I’m still very proud to have done this. At the time of this post it is my most ridden bike. I ride it several times a week at least. I call it the Guppy.
A custom top load stem.
Second frame build. A pretty big step up in difficulty from my first frame. This bike met and surpassed all my expectations. It’s long, heavy, and an absolute seld downhill and up steep climbs. I call it the Hog.
Third frame coming soon! This one is a gravel bike. I might stick with the animal names and call it the Goose.
I don’t know what my future as a hobby framebuilder will look like. After this gravel bike I will have three bikes, which is all the bikes I need and have the space for. I may start iterating on my existing frames or start making components. I’m also at the point where I think I would be willing to make a frame for a friend. Either way, I really enjoy this craft and I’m glad to be a student of framebuilding
Hello all, I’m Ted (he/him) living near Peterborough-Nogojiwanong, Ontario, Canada. I’m dusting off my framebuilding projects after a ten year pause. I’m working on my 4th and 5th frames, one is a lugged relaxed road bike and the other is a copy of a WW2 BSA military folding bike.
I got the bug when I painted our local pro framebuilder’s house in 1992, Julian Edwins in Owen Sound Ontario. He very generously showed me his shop and told me as much as I could absorb about his craft. A few years later I was working one day a week at a bike shop in Victoria BC and one of the mechanics and I got some tubes and made a couple frames.
I got into mountain biking on Vancouver Island in the early 90s and love that period of rigid bikes so much, I still have a Bridgestone MB2 and a Bianchi Denali RC.
I’m looking forward to seeing the creativity of all you pros and hobbyists and hope to learn some proper techniques since I’ve been winging it so far.
Hello from Greenfield, near Oldham in the UK :wave:
I built a chunky MTB frame at the Bicycle Academy three years ago: a long-slack hardtail with space for 2.6" tyres. I quickly got over my fear of it falling apart on the downhills, and she’s become my favourite bike in the world ever. My previously beloved full-sus languishes unridden at the back of the garage.
I’d love to build more, but hadn’t summoned the commitment until I chatted to Pi from Clandestine Cycles at Bespoked this year. Since then I’ve picked up a second hand LCFF, and am collecting the remaining bits I need to get started. Also clearing space in the garage, which is arguably more difficult.
I’m looking forward to wielding a torch again, and very grateful for this forum!
@lentilshepherd Welcome!
That is a good-looking hardtail! Well proportioned.
¡Hola a todo el mundo!
This is Andrés from arreguivelazquez.com and etbacademy.com (as in Escuela Técnica de la Bicicleta Academy, formerly etbicicleta.com). My background is in chemistry (I finished my PhD in Chemical Physics in 2009), but I’ve been designing and making bicycles for 15 years or so. Now we (as in Alexey, Jaime, and I) are involved in teaching bicycle design and manufacturing, research (iberg-bike.org, Universidad Complutense Madrid, and Universidad Europea de Madrid), prototyping for brands, and custom + serial building in AV or others.
Live in Madrid with Laura and our two kids, Gaspar and Tirso (9 and 12).
Love steel fillet-brazed bikes (brass and silver), but we make TIG (Alex does) and CF 3D-printed stuff too.
We break a lot of bikes in ISO testing to learn how to make them better.
We have designed and made bikes for people from 1.20 to 2.10 m, with a huge variety of styles including city rental electric bikes, mini velos or CargoBMXgravels.
Im also the director of a Master’s in Product Design (Universidad Europea).
I mainly use the bike to move around and discover places, go to work, or head to my favorite DIY skatepark (to skate) or to build ramps.
I’ve been playing sax for 25 years, and I’m really good at making noise.
I still love Flickr: Flickr Albums (I’m old).
Small summary of what I’m up to. All questions welcome!
I’ll be around since I’m interested to see where all this is going (I already see some familiar faces!). Lots of interesting stuff here!.
Beautiful work @Arregui Andres. Hope to pick up some knowledge from your contribution.
