Nachlin MK II mini cargo bike
I’m unemployed, so I thought I’d spend some time making a new bike for myself. I had this set of Brompton-sized wheels, with the rear laced to a Bendix coaster brake, so those will be the wheels. I have a lot of scrap and left over straight gauge tubing as well. So here goes.
I usually start with a big drawing. Here I have sorted through what I have and am figuring out what tubes to use for what. Back when tubing was a lot cheaper, whenever I’d order some straight gauge, I’d add a random tube or two because shipping was the same.
That done, I started in rough cutting and cleaning the tubes.
Then I made some rear dropouts (track ends).
A lot of this bike is very improvisational.
I brazed a couple sleeves onto the head tube, and a short “lug” for the down tube
My brazing is rough. I haven’t built a bike for more than two years. Also, my friend got a new torch and it’s taking some getting used to. But I’m trying to focus on smaller fillets, going slower.
The fork has to have a really long steerer, and accommodate a 74mm wide hub.
I had this old kids’ bike fork
Trimmed the legs off
Sleeved the steerer both inside and out
And so here’s the fork.
Some days I don’t take as many pictures. Anyway, front triangle time.
Here the ST is already joined to the BB. So is the DT. I did that joint in a similar way to what you see here, using tube blocks clamped down on the metal table to keep things aligned.
The chain stays are brazed into a couple of sockets I’d already brazed onto the BB. This technique makes up for my lack of a frame jig by allowing me to position the chain stays and have them somewhat stay put for brazing. Despite that it took a good deal of yanking to get the whole thing straight.
Now the “backbone” is done and I can more or less move forward without such complex alignment steps.
The lower part of the head tube will be trimmed close to the DT.
Here’s where we are. A lower plate has been added to the fork crown.
Wheelbase is 117 cm or so. Effective top tube will be about 63 cm.
Is this the first twin plate unicrown 74mm OLD fork in existence?
I mentioned this whole thing is kind of improvisational. So today I spent some time thinking about how the racks are going to be. The rear won’t really have seat stays. The brazed-on rack is going to do that job.
So these aluminum rods are just helping me visualize.
And this one is helping me see where the chain needs to go. I have built this style of bike a couple times, and once I put one of the rack supports right where the chain wanted to be.
Sticking more stuff to other stuff in a futile attempt at meaningfulness.
Today, top tube, front rack.
Top tube was easy.
Rack is sort of a rainbow in curved air.
As usual, the fixturing situation is a little freestyle
Then to join it to the head tube.
Entonces
There will be more to support that front rack. Not totally sure what. Then on to the back end.
Small snag today
Did I bend those other tubes with someone else’s bender? I can’t remember.
This guy is not talking.
This looks so fun :star_struck:
Can’t wait to see the rest of the project
:muscle::heart_hands::fire:
This week I have been working on the rear rack, which will be an integral part of the frame.
I went back to paper and pencil to work out the shape, then started bending metal bits.
Today I got over to my friend’s shop to do some brazing. As usual, the fixturing is pretty loose.
Internal vent holes where the tubes join each other.
To my chagrin, the end result looks a bit like a weenie.
I was going to braze this whole thing onto the frame but I paused. My fixturing situation is not great, and I don’t want to fuck this up. So I will work on something more rigid than what I have now, and return to it next week.
Made one of these and wonder why I hadn’t sooner.
Triangulation, ha!
(Triangles will be added later)
(Also the rack is horizontal but there’s no fork on the other end in this photo)
What remains is something to support the rear, because it’s too weak as it is, and something under the front rack as well. Then braze-ons for a chain guard and of course the head badge or some sort of marker.
I have these Ns which I tried stamping, but the stamps deform the metal - which might be OK. Not sure yet.
Ok triangulation. Been sick so things are a bit slow at the mome.
Put some little fenders on there to see how they fit. They’re just balancing on the tires - rest assured, once installed, fender lines will be 100.
I was going to add a support at the front but ran out of time. All that remains after that is some chain case braze ons and to cut the seat tube slot. I’ve never done a straight one. Will this be the first time?
Not too much progress lately. Brazing is done (for now). Planning to spend most of
2025 doing the finish work. This bike is made of 47 separate pieces. I think I’ll do something simpler next.
Oh, Hi!
Just over here testing parts fit on this mini cargo bike. So far, no disasters. Been rather busy but I want to get a couple more things stuck to it and then I’ll take it apart again and paint it.
Also got to figure out where to cut the extremely long steerer.
But it’s a bike now!
Looks amazing! Wheelbase looks close to a regular bike. How does it ride?
I have not ridden a lot yet but it seems very normal. Steering is very light, however, maybe due to the tiny weight and rotating mass of the front wheel.
Length overall is just the same as my Bridgestone touring bike.
That was part of the design goal, because carrying my other cargo bike up and down from my basement is a big challenge - lots of tire marks on the walls.
Just some shots while riding around. Paint will come when it gets warm out.
Update: I ride this bike all the time now. I still haven’t painted it.
